Old July 25th, 2007   #2 (permalink)
slinley
Default Re: incremental add to current map irradiance map settings
Originally Posted by Boing View Post
First is this going to work?
Secondly, There's a box beneath which says "auto save" is this to save the incremental map file? should it be ticked?
First, yes it will work. Just make sure you save the file on your server using an unconnected network path and then when you send the renders point it to the same file using the same path (Not using mapped network drive letters).
Secondly, don't think you do need the autosave ticked but maybe someone else can better advise.
slinley is offline   Reply With Quote
