Re: incremental add to current map irradiance map settings
Yes, in the section "on render end" activate DONT DELETE, AUTO SAVE (indicate the path where you want to save de IMAP, that must be the path all computers will find - network path) and if you are going to use the copy of same archive in all computers (recomended) activate switch to saved map.
Dont forget "Dont Render final image" in global settings
Maybe flickering is not a complete imap issue... using precalc will help a lot with time, but make sure to check another settings to fix flikering....
