Old June 2nd, 2006   #1 (permalink)
Philippines
Default Animation in VRAY flickering?
hi, im a newbie in everything regarding 3d modeling, im just doing a little animation using max 7 with vray... the problem is the animation is flickering... it seems like in every frame rendered, a slightly different shade of color is rendered, that's why when it is animated, we get the flickering effect...
im doing a flyby animation of a building...
btw, some follow up questions:
1. what codecs should i be using?
2. what size/resolution should i use?
3. what screen aspect ratio?
4. how to get rid of the flickering of the animation
the animation will most likely be played on a tv and also will be projected into a wall, it is part of a gimmick during the launching/inauguration of the said building... hoping to hear from you guys and thanks in advance...
charadesia is offline
Old June 3rd, 2006   #2 (permalink)
Default Re: Animation in VRAY flickering?
hi,
if the animation will be played on the T.V
i guess u have to choose between Pal or NTSC,the one that suits the broadcast in ur country,u can get that from the output size.
regarding the flickering please post ur vray settings and lets see whats wrong with it.
regards.
M.J.Anani
colorID is offline
Old June 3rd, 2006   #3 (permalink)
RamiroB2's Avatar
Name: Ramiro Bentancourt.
Argentina
http://www.cgarchitect.com/vb/16830-...ght=flickering
http://www.cgarchitect.com/vb/16964-...ght=flickering
RamiroB2 is offline
Help Vray Animation gods418 Work in Progress (WIP) 14 May 29th, 2006 04:03 AM
what is the best animation configuration for VRay? Ghiath VRay Render 5 February 2nd, 2006 01:06 PM
vray animation question kamikaze VRay Render 8 December 7th, 2005 01:02 PM
What is the best setting for animation using VRAY? cxdesigner VRay Render 2 July 13th, 2005 01:14 AM
Vray Animation - Please Help! stylez 3ds Max 7 May 24th, 2004 11:31 PM
