Name: Sean Ahlquist |
I have a polygon mesh from Rhino that i need to simplify. Is there a software out there or a plug-in for something like Rhino or MAX that can take a large polygon mesh and cleanly simplify the model - ie - reduce the poly count?
This is for a model that is being built on an SLA machine. Because of the current high poly count, the machine will not accept the file. i looked at something like PolyTrans, but it was hard to determine if that was a function inside the software. any suggestions would be great. thanks, sean |
Name: Joseph Alexander |
downloard rhino 4.
"QuadrangulateMesh" this may reduce your mesh count 1/3 Are you meshing a nurb? To do so do the following: reduce it to the size of the part 1:1 scale. make sure your units are in inches. then mesh using these settings. maximum angle: 0 maximum aspect ratio 6 minimum edge length .0001 maximum edge length 0 maximum distance, edge to surface .001 Check: Refine Mesh all else unchecked export. Last edited by joseph alexander; June 6th, 2006 at 11:09 AM. |
| C4D polygon limits? | josephus | Cinema 4D | 1 | May 7th, 2006 11:16 PM |
| Radiosity - Trouble Meshing Interior Objects | MegaPixel | 3ds Max | 5 | July 20th, 2005 04:03 PM |
| polygon count increase (lock mesh set), why ? | Lioric | Lightscape | 4 | August 23rd, 2003 02:15 PM |
| polygon modeling | proces2 | 3ds Max | 4 | May 16th, 2003 11:47 AM |
| Max 5 Rad meshing | jucaro | 3ds Max | 4 | December 27th, 2002 05:08 AM |
