Re: More Advice on Becoming an Arch. Visualizer
Nathon,
You did kind of ramble there - but I think you at the least presented your position clearly. Here are a couple of comments from my perspective - these are MY opinions, and may not be shared by others.
Your desire and drive to move up to a larger firm is admirable, however your experience and background don't currently jive with what larger firms are looking for, as you identified. If you look at the gallery here - the level of work that you will need to achieve as a visualizer candidate for these firms is lofty, and may take many years (if at all) to achieve. Likewise - CADD / technology management at this level is played on a whole different level. You need a vast and varied background, and the type of technology resume that takes years to accomplish.
Learning 3D modeling under the tutelage of your Architect friend would be a good first move. But don't expect that modeling will teach you how to read architectural plans - rather the other way around. It can not be emphasized enough how critical this is - big firms won't even consider you unless you have a thorough understanding of and can read plans.
As with any beginner - I would encourage you to use "free" softwares when available to develop your skills and experience. Start with the free sketchup and model anything you can. While all 3D softwares are similar - they are also very different. If you get really good at one - the transition to another is much easier. Revit is the future in the AE industry - but it is so design based and oriented that unless you truly understand what it is that you are modeling - it will be a struggle.
While they may not come across that way - my word are intended to be encouraging. I hope they are of some help to you!
Dean
