Old October 5th, 2007   #3 (permalink)
ameo
Bulgaria
Default Re: Top / Bottom Material
""The object's top faces are those whose normals point up. The bottom faces have normals that point down. You can choose whether "up" and "down" refer to the scene's world coordinates or to the object's local coordinates.""
In your box all side faces are with one normal pointing at 90 degrees in world coordinates.
In cone situation is the same, but all side polys are with normals pointing up.
ameo is offline   Reply With Quote
