3ds Max Autodesk 3ds Max
Old July 13th, 2006   #1 (permalink)
baker1444's Avatar
Default Material Editor not showing Materials
Hi everyone,
I'm having trouble with the display in my material editor. As you can see from the attached picture the materials do not display my materials properly. In the picture attached I have the max standard finishes material library open and as you can see its not showing the diffuse map. The glossyness and specular are showing but I find it hard knowing what I'm picking when I can't tell what kind of map it is. The materials render fine but just don't display properly. Has anyone experieced this before? I'm using Max 8 with service pack 3 and real dwg 2007. Can anyone fix this?
baker1444 is offline
Old July 14th, 2006   #2 (permalink)
arquiteck09's Avatar
Mexico
Default Re: Material Editor not showing Materials
i was going to ask you if you have the maps installed, but you said that they render properly, maybe reinstalling the software.
arquiteck09 is offline
Old July 14th, 2006   #3 (permalink)
baker1444's Avatar
Yeh actualy I did a complete format of my system and it still occures. Not a big issue but it just is annoying.
Old July 14th, 2006   #4 (permalink)
Philippines
i have the same problem.pls help us.....its hard to use the materials without seeing what they look like esp when ur new at 3dsmax..like me...
fulin09 is offline
Old August 13th, 2006   #5 (permalink)
PAWUK's Avatar
Lightbulb Re: Material Editor not showing Materials
Dont know if its still off any use but have you gone thru the customize menu and then configure user paths
PAWUK is offline
Old August 14th, 2006   #6 (permalink)
Verma's Avatar
Which rendering engine are you using for material editor?
Try changing that between MR and Scanline.
Multimedia Manager
www.ideateinc.com
Verma is offline
Old August 14th, 2006   #7 (permalink)
In your Diffuse Map properties, under the Coordinates category, turn Use Real-World Scale off.
tstephens is offline
vray tip for those using architectural materials crazy homeless guy VRay Render 17 September 9th, 2006 12:55 AM
shell material v-cube 3ds Max 1 May 19th, 2006 09:31 PM
mr problem with glass mr material with dielectric msamer 3ds Max 9 April 6th, 2006 11:34 AM
Chrome material problem evanmoses VRay Render 18 March 16th, 2005 09:12 AM
