Re: Rotating objects to alignment in Viz
There is only one option that I know of. If you 'align' an object to another there is an option algin the objects xyz orientation to that of the other object. This works some times - however - the more abstract the shape the less it works. From your image it looks like it might work. Align 1 to 2 and check align orientation for x y z. Good luck.
Some one should put rotate reference (like in AutoCad) on Autodesk's "wish list"
