Old November 1st, 2007   #6 (permalink)
jvlive
jvlive's Avatar
Name: julius hontarigo
Philippines
Default Re: Rotating objects to alignment in Viz
Hi James,
I think marksee's suggestion will work, if indeed your target is to align object 1 to object 2. You just need to combine the "align position" and "align orientation" axes (see attached gif).
On the other hand, you said:
Originally Posted by JamesTaylor View Post
i'm aware of using the align tool, but unless i've missed a trick it only aligns the entire object to another object in relation to the specified world / local / view axis chosen.
what i need to do is align a certain section of an object to a particular section of another, i've attached a screen grab to better illustrate it.
You seem to want just a particular section of object1 to align with object 2. In this case, the best thing I could think of is moving vertices. Or maybe try normal align (havent tried it though).
Hoped that helped.
p.s. hope this gif works, its my first!
the early bird gets the worm, but hey, the late worm missed the bird.
jvlive is offline   Reply With Quote
