There is no way to run the installer using Vista x64, but Thats what Iam using, and together with Lightscape
Dont know why though, there is something about Lightscape.......Except the radiosity artifacts...
But it´s still a very cool software.
This is how I done it. I had to install on my old Dell 32-bit xp workstation, I copied all reg entries and saved as a .reg file. Copied the installed Lightscape folder into the very same path from the root. For me it was c:\program files\Lightscape.
Here is the reg entries, you can just edit the serial, and or the path in any asci editor, like "notepad" etc.....
Just copy the text into notepad and save the file as .reg. Klick the file and you have all reg data as needed.....
Dont copy my double slash..
Windows Registry Editor Version 5.00
; File created by TBackupTool
; Component version: 1.4.1
; Component used by: jv16 PowerTools 2007
; Program Files version: 1.7.0.416
; File Description:
; Date: 16.11.2007
; Time: 11:55:37
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\3. 2\Profile\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\3. 2\]
"InstallRoot"="C:\\Program Files\\Lightscape"
"Program FilesFolder"="Lightscape"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\Ma p\&Help\&Lightscape Web Site\]
"&Lightscape"="
http://ktx.com/lsredir/index.htm?link=lscape"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\Ma p\&Help\&Support\]
"Lightscape &Support Web Site"="
http://ktx.com/lsredir/index.htm?link=lscapesupport"
"Frequent &Questions"="
http://ktx.com/lsredir/index.htm?link=lscapefaq"
"&Visual Trouble Shooter"="
http://ktx.com/lsredir/index.htm?link=lscapevts"
"Support &Form"="
http://ktx.com/lsredir/index.htm?link=lscapesupportform"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\Ma p\&Help\Lightscape &User Community\]
"&Web Board Forum"="
http://ktx.com/lsredir/index.htm?link=lscapewebboard"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\Ma p\&Help\]
"_1"=hex:00,02,00,01,00,01,00,02
"&Release Notes"="%__THIS_APP_FOLDER__%\\..\\ReadMe.txt"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\Ma p\&Tools\]
"_1"=hex:00,02,00,01,00,06,00,02
"&LVu"="%__THIS_APP_FOLDER__%\\LVU.EXE"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\Ma p\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\Ph otometric Web Paths\]
"Lesson6"="C:\\Program Files\\Lightscape\\Projects\\lesson6\\"
"0"="C:/Program Files/Lightscape/Projects/lesson6"
"1"="C:/Program Files/Lightscape/Projects"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\Te xture Paths\]
"0"="C:/Program Files/Lightscape/Projects"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Lightscape\]
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\Dialogs\]
"GeomMainWindow"=hex:00,00,00,00,00,00,00,00,C0,03 ,00,00,D0,02,00,00
"GeomOList#0"=hex:01,00,00,00,8B,04,00,00,00,00,00 ,00,00,05,00,00,E7,00,00,00,01,00,00,00,40,00,\
00,00,8B,04,00,00,00,00,00,00,00,05,00,00,E7,00,00 ,00,01,00,00,00,40,00,00,\
00
"GeomOList#1"=hex:01,00,00,00,8B,04,00,00,E7,00,00 ,00,00,05,00,00,CE,01,00,00,01,00,00,00,40,00,\
00,00,8B,04,00,00,E7,00,00,00,00,05,00,00,CE,01,00 ,00,01,00,00,00,40,00,00,\
00
"GeomOList#5"=hex:01,00,00,00,8B,04,00,00,CE,01,00 ,00,00,05,00,00,B5,02,00,00,01,00,00,00,40,00,\
00,00,8B,04,00,00,CE,01,00,00,00,05,00,00,B5,02,00 ,00,01,00,00,00,40,00,00,\
00
"GeomOList#3"=hex:01,00,00,00,8B,04,00,00,B5,02,00 ,00,00,05,00,00,9C,03,00,00,01,00,00,00,40,00,\
00,00,8B,04,00,00,B5,02,00,00,00,05,00,00,9C,03,00 ,00,01,00,00,00,40,00,00,\
00
"Geom10089"=hex:94,03,00,00,C3,02,00,00,00,05,00,0 0,9F,03,00,00
"Geom10663"=hex:A8,03,00,00,78,02,00,00,00,05,00,0 0,9F,03,00,00
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar0\]
"BarID"=dword:0000E801
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar1\]
"BarID"=dword:0000006A
"XPos"=dword:FFFFFFFE
"YPos"=dword:FFFFFFFE
"Docking"=dword:00000001
"MRUDockID"=dword:00000000
"MRUDockLeftPos"=dword:FFFFFFFE
"MRUDockTopPos"=dword:FFFFFFFE
"MRUDockRightPos"=dword:000000BF
"MRUDockBottomPos"=dword:0000001E
"MRUFloatStyle"=dword:00002004
"MRUFloatXPos"=dword:80000000
"MRUFloatYPos"=dword:00000000
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar10\]
"BarID"=dword:0000E81B
"Bars"=dword:0000000C
"Bar#0"=dword:00000000
"Bar#1"=dword:0000006A
"Bar#2"=dword:0000006D
"Bar#3"=dword:000000AC
"Bar#4"=dword:0000006E
"Bar#5"=dword:0000006F
"Bar#6"=dword:00000000
"Bar#7"=dword:000000A9
"Bar#8"=dword:00000132
"Bar#9"=dword:000000A1
"Bar#10"=dword:000000AD
"Bar#11"=dword:00000000
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar2\]
"BarID"=dword:000000A9
"YPos"=dword:0000001C
"MRUDockTopPos"=dword:0000001C
"MRUDockRightPos"=dword:0000018F
"MRUDockBottomPos"=dword:0000003C
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar3\]
"BarID"=dword:0000006E
"XPos"=dword:00000287
"MRUDockLeftPos"=dword:00000287
"MRUDockRightPos"=dword:0000030A
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar4\]
"BarID"=dword:0000006D
"XPos"=dword:000000BD
"MRUDockLeftPos"=dword:000000BD
"MRUDockRightPos"=dword:0000016E
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar5\]
"BarID"=dword:000000A1
"XPos"=dword:000002A8
"MRUDockLeftPos"=dword:000002A8
"MRUDockRightPos"=dword:00000314
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar6\]
"BarID"=dword:0000006F
"XPos"=dword:00000308
"MRUDockLeftPos"=dword:00000308
"MRUDockRightPos"=dword:000003D0
"MRUFloatYPos"=dword:032E48C8
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar7\]
"BarID"=dword:000000AC
"XPos"=dword:0000016C
"MRUDockLeftPos"=dword:0000016C
"MRUDockRightPos"=dword:00000289
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar8\]
"BarID"=dword:000000AD
"XPos"=dword:00000312
"MRUDockLeftPos"=dword:00000312
"MRUDockRightPos"=dword:0000037E
"MRUFloatYPos"=dword:01080155
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Bar9\]
"BarID"=dword:00000132
"XPos"=dword:0000018D
"MRUDockLeftPos"=dword:0000018D
"MRUDockRightPos"=dword:000002AA
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\TBars-Summary\]
"Bars"=dword:0000000B
"ScreenCX"=dword:00000500
"ScreenCY"=dword:000003C0
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Cur rentVersion\]
"MainWindow Maximized"=hex:01,00,00,00
"OList#0 Open"=hex:01,00,00,00
"OList#1 Open"=hex:01,00,00,00
"OList#5 Open"=hex:01,00,00,00
"OList#3 Open"=hex:01,00,00,00
"Tool PickFilterMode"=hex:00,00,00,00
"Tool PickMode"=hex:01,00,00,00
"Tool DrawMode"=hex:C5,00,00,00
"Tool DisplayMode"=hex:13,00,00,00
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Dra gIncrements\]
"Position"="1, 1, 1, 0"
"Angle"="0,174533, 0,174533, 0,174533, 0"
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\lt3 ds.dll\]
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Mat erial Preview\]
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\MRU Sizes\]
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Pho tometric Web Paths\]
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Pre ferences\]
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Set tings\]
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\Tex ture Paths\]
[HKEY_CURRENT_USER\Software\Autodesk\Lightscape\]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\MenuOrder\Start Menu2\Program Filess\Lightscape\]
"Order"=hex:08,00,00,00,02,00,00,00,70,05,00,00,01 ,00,00,00,0A,00,00,00,7E,00,00,00,00,00,\
00,00,70,00,00,00,41,75,67,4D,02,00,00,00,01,00,00 ,00,5E,00,32,00,9C,02,00,\
00,46,37,5A,65,20,00,4C,49,47,48,54,53,7E,31,2E,4C ,4E,4B,00,00,34,00,03,00,\
04,00,EF,BE,46,37,5A,65,4D,37,80,23,14,00,00,00,4C ,00,69,00,67,00,68,00,74,\
00,73,00,63,00,61,00,70,00,65,00,2E,00,6C,00,6E,00 ,6B,00,00,00,1C,00,0E,00,\
00,00,0A,00,EF,BE,00,00,00,00,1C,00,00,00,00,00,00 ,00,00,00,88,00,00,00,01,\
00,00,00,7A,00,00,00,41,75,67,4D,02,00,00,00,01,00 ,00,00,68,00,32,00,9C,02,\
00,00,46,37,5A,65,20,00,4C,49,47,48,54,53,7E,32,2E ,4C,4E,4B,00,00,3E,00,03,\
00,04,00,EF,BE,46,37,5A,65,4D,37,80,23,14,00,00,00 ,4C,00,69,00,67,00,68,00,\
74,00,73,00,63,00,61,00,70,00,65,00,20,00,48,00,65 ,00,6C,00,70,00,2E,00,6C,\
00,6E,00,6B,00,00,00,1C,00,0E,00,00,00,0A,00,EF,BE ,00,00,00,00,1C,00,00,00,\
00,00,00,00,00,00,9C,00,00,00,02,00,00,00,8E,00,00 ,00,41,75,67,4D,02,00,00,\
00,01,00,00,00,7C,00,32,00,E0,02,00,00,46,37,13,66 ,20,00,4C,49,38,38,42,42,\
7E,31,2E,4C,4E,4B,00,00,52,00,03,00,04,00,EF,BE,46 ,37,13,66,4D,37,80,23,14,\
00,00,00,4C,00,69,00,67,00,68,00,74,00,73,00,63,00 ,61,00,70,00,65,00,20,00,\
4C,00,69,00,62,00,72,00,61,00,72,00,69,00,65,00,73 ,00,20,00,48,00,65,00,6C,\
00,70,00,2E,00,6C,00,6E,00,6B,00,00,00,1C,00,0E,00 ,00,00,0A,00,EF,BE,00,00,\
00,00,1C,00,00,00,00,00,00,00,00,00,A0,00,00,00,03 ,00,00,00,92,00,00,00,41,\
75,67,4D,02,00,00,00,01,00,00,00,80,00,32,00,91,02 ,00,00,46,37,13,66,20,00,\
4C,49,47,48,54,53,7E,34,2E,4C,4E,4B,00,00,56,00,03 ,00,04,00,EF,BE,46,37,13,\
66,4D,37,80,23,14,00,00,00,4C,00,69,00,67,00,68,00 ,74,00,73,00,63,00,61,00,\
70,00,65,00,20,00,4C,00,69,00,62,00,72,00,61,00,72 ,00,69,00,65,00,73,00,20,\
00,52,00,65,00,61,00,64,00,6D,00,65,00,2E,00,6C,00 ,6E,00,6B,00,00,00,1C,00,\
0E,00,00,00,0A,00,EF,BE,00,00,00,00,1C,00,00,00,00 ,00,00,00,00,00,8C,00,00,\
00,04,00,00,00,7E,00,00,00,41,75,67,4D,02,00,00,00 ,01,00,00,00,6C,00,32,00,\
60,02,00,00,46,37,5A,65,20,00,4C,49,47,48,54,53,7E ,33,2E,4C,4E,4B,00,00,42,\
00,03,00,04,00,EF,BE,46,37,5A,65,4D,37,80,23,14,00 ,00,00,4C,00,69,00,67,00,\
68,00,74,00,73,00,63,00,61,00,70,00,65,00,20,00,52 ,00,65,00,61,00,64,00,4D,\
00,65,00,2E,00,6C,00,6E,00,6B,00,00,00,1C,00,0E,00 ,00,00,0A,00,EF,BE,00,00,\
00,00,1C,00,00,00,00,00,00,00,00,00,7A,00,00,00,05 ,00,00,00,6C,00,00,00,41,\
75,67,4D,02,00,00,00,01,00,00,00,5A,00,32,00,A8,02 ,00,00,46,37,5A,65,20,00,\
4C,53,76,69,65,77,65,72,2E,6C,6E,6B,00,00,30,00,03 ,00,04,00,EF,BE,46,37,5A,\
65,4D,37,80,23,14,00,00,00,4C,00,53,00,76,00,69,00 ,65,00,77,00,65,00,72,00,\
2E,00,6C,00,6E,00,6B,00,00,00,1C,00,0E,00,00,00,0A ,00,EF,BE,00,00,00,00,1C,\
00,00,00,00,00,00,00,00,00,6A,00,00,00,06,00,00,00 ,5C,00,00,00,41,75,67,4D,\
02,00,00,00,01,00,00,00,4A,00,32,00,89,02,00,00,46 ,37,5A,65,20,00,4C,56,75,\
2E,6C,6E,6B,00,26,00,03,00,04,00,EF,BE,46,37,5A,65 ,4D,37,80,23,14,00,00,00,\
4C,00,56,00,75,00,2E,00,6C,00,6E,00,6B,00,00,00,16 ,00,0E,00,00,00,0A,00,EF,\
BE,00,00,00,00,16,00,00,00,00,00,00,00,00,00,7A,00 ,00,00,07,00,00,00,6C,00,\
00,00,41,75,67,4D,02,00,00,00,01,00,00,00,5A,00,32 ,00,54,02,00,00,46,37,5A,\
65,20,00,50,72,6F,6A,65,63,74,73,2E,6C,6E,6B,00,00 ,30,00,03,00,04,00,EF,BE,\
46,37,5A,65,4D,37,80,23,14,00,00,00,50,00,72,00,6F ,00,6A,00,65,00,63,00,74,\
00,73,00,2E,00,6C,00,6E,00,6B,00,00,00,1C,00,0E,00 ,00,00,0A,00,EF,BE,00,00,\
00,00,1C,00,00,00,00,00,00,00,00,00,92,00,00,00,08 ,00,00,00,84,00,00,00,41,\
75,67,4D,02,00,00,00,01,00,00,00,72,00,32,00,AB,02 ,00,00,46,37,5A,65,20,00,\
55,4E,49,4E,53,54,7E,31,2E,4C,4E,4B,00,00,48,00,03 ,00,04,00,EF,BE,46,37,5A,\
65,4D,37,80,23,14,00,00,00,55,00,6E,00,69,00,6E,00 ,73,00,74,00,61,00,6C,00,\
6C,00,20,00,4C,00,69,00,67,00,68,00,74,00,73,00,63 ,00,61,00,70,00,65,00,2E,\
00,6C,00,6E,00,6B,00,00,00,1C,00,0E,00,00,00,0A,00 ,EF,BE,00,00,00,00,1C,00,\
00,00,00,00,00,00,00,00,A6,00,00,00,09,00,00,00,98 ,00,00,00,41,75,67,4D,02,\
00,00,00,01,00,00,00,86,00,32,00,53,02,00,00,46,37 ,13,66,20,00,55,4E,49,4E,\
53,54,7E,32,2E,4C,4E,4B,00,00,5C,00,03,00,04,00,EF ,BE,46,37,13,66,4D,37,80,\
23,14,00,00,00,55,00,6E,00,69,00,6E,00,73,00,74,00 ,61,00,6C,00,6C,00,20,00,\
4C,00,69,00,67,00,68,00,74,00,73,00,63,00,61,00,70 ,00,65,00,20,00,4C,00,69,\
00,62,00,72,00,61,00,72,00,69,00,65,00,73,00,2E,00 ,6C,00,6E,00,6B,00,00,00,\
1C,00,0E,00,00,00,0A,00,EF,BE,00,00,00,00,1C,00,00 ,00,00,00,00,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\App Management\ARPCache\LightscapeDeinstKey3.2\]
"SlowInfoCache"=hex:28,02,00,00,01,00,00,00,00,80, 8C,19,00,00,00,00,FF,FF,FF,FF,FF,FF,FF,FF,0F,00,\
00,00,43,00,3A,00,5C,00,50,00,72,00,6F,00,67,00,72 ,00,61,00,6D,00,5C,00,4C,\
00,69,00,67,00,68,00,74,00,73,00,63,00,61,00,70,00 ,65,00,5C,00,62,00,69,00,\
6E,00,5C,00,33,00,64,00,73,00,32,00,6C,00,70,00,2E ,00,65,00,78,00,65,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00 ,00,00,00,00,00,00,00,00,\
00
"Changed"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\App Paths\Libs.exe]
@="C:\\Program Files\\Lightscape\\HELP\\LIBRARIES.HLP"
"Path"="C:\\Program Files\\Lightscape\\HELP"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\App Paths\lscape.exe]
@="C:\\Program Files\\Lightscape\\bin\\LSCAPE.EXE"
"Path"="C:\\Program Files\\Lightscape\\bin"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall\LibsDeinstKey]
"DisplayName"="Lightscape Libraries"
"UninstallString"="C:\\WINDOWS\\uninst.exe -fC:\\Program Files\\Lightscape\\DeIsL1.isu"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall\LightscapeDeinstKey3.2\]
"UninstallString"="C:\\WINDOWS\\uninst.exe -fC:\\Program Files\\Lightscape\\LightscapeSetup\\DeIsL2.isu -cC:\\Program Files\\Lightscape\\LTUNINST.DLL"
"DisplayName"="Lightscape 3.2"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Se ssion Manager\Environment]
"LVS_IES_PATH"="C:\\Program Files\\Lightscape\\Lib\\lights\\IES"
"LVS_TEXTURE_PATH"="C:\\Program Files\\Lightscape\\Lib\\material\\textures"
[HKEY_CLASSES_ROOT\CLSID\{80D3A074-B508-11D0-8C39-0060976E85D5}]
@="Lightscape Map Plug-In"
[HKEY_CLASSES_ROOT\CLSID\{80D3A075-B508-11D0-8C39-0060976E85D5}]
@="Lightscape Map Plug-In Property Page"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\Se ssion Manager\Environment]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager\Environment]
[HKEY_CLASSES_ROOT\LScape.Block.Document]
@="Lightscape Block Document"
[HKEY_CLASSES_ROOT\LScape.Material.Document]
@="Lightscape Material Document"
[HKEY_CLASSES_ROOT\LScape.Preparation.Document.20]
@="Lightscape Preparation Document"
[HKEY_CLASSES_ROOT\LScape.Solution.Document.20]
@="Lightscape Solution Document"
[HKEY_CLASSES_ROOT\LTPIMAP.LtPIMapCtrl.1]
[HKEY_CLASSES_ROOT\TypeLib\{80D3A071-B508-11D0-8C39-0060976E85D5}\1.0]
@="Lightscape Map Plug-In Control"
[HKEY_CLASSES_ROOT\TypeLib\{80D3A071-B508-11D0-8C39-0060976E85D5}\1.0\0\win32]
@="C:\\Program Files\\Lightscape\\bin\\ltpimap.ltc"
[HKEY_CLASSES_ROOT\TypeLib\{80D3A071-B508-11D0-8C39-0060976E85D5}\1.0\HELPDIR]
@="C:\\Program Files\\Lightscape\\bin"
[HKEY_CLASSES_ROOT\TypeLib\{DF2CE6F0-FB97-11CF-9E8C-00AA0064216A}\3.2\0\win32]
@="C:\\Program Files\\Lightscape\\bin\\ltimg.ocx"
[HKEY_CLASSES_ROOT\TypeLib\{DF2CE6F0-FB97-11CF-9E8C-00AA0064216A}\3.2\HELPDIR]
Cheers and best of luck......
