Old November 19th, 2007   #1 (permalink)
BrianKitts
BrianKitts's Avatar
Default Historical Frame buffer memory
The frame buffer should have the ability to flip back through previous renders.
I heard mention that lightwave once had an option that it stored all of your renderings in a working session within it's frame buffer. Then you could step back through your history to compare/reference previous working renderings.
It would be a temporary memory that you could dump to reclaim resources, and of course you would lose it when closing the file, but during an active session your history could be cached.
This could be useful when adjusting lighting and texture for comparing the quality/results. Basically you would have the ability to comparing renders within max instead of having to save out images to be flipped through in an external application.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline   Reply With Quote
