Old November 20th, 2007   #1 (permalink)
gfa2
gfa2's Avatar
Default Render elements and split scan lines with Backburner
Currently (unless I'm missing something) you cannot send a rendering to Backburner that includes split scan lines and Render elements. I'd like to see that corrected.
I'd like to be able to send a high resolution image to Backburner, have an entire renderfarm work on the single image and save out the separate render elements for use in post compositing work. This work-flow is great when using a single machine to produce the rendering, why shouldn't we be able to benefit from this with multiple machines doing the work?
gfa2 is offline   Reply With Quote
