Old August 9th, 2006   #1 (permalink)
Belgium  Send a message via MSN to t.fzr
Question file link ADT window/door
Hello,
I have a question about file linking an ADT file to max. In ADT I made some AEC windows, I file linked the file in max. But my problem now is that when I want to select the frame of that window to put some kind of material on, I get the hole window (frame+glass)... so it acts like a block.
Is there a way to file link AEC windows/doors/railings so that you can select the elements seperatly?
Greetings
t.fzr is offline
Old August 9th, 2006   #2 (permalink)
Chad Warner's Avatar
Default Re: file link ADT window/door
There's an option when you link the dwg under the advanced tab, that says "create one scene object for each ADT object" if you uncheck that, you'll get the different components.
Chad Warner is offline
Old August 9th, 2006   #3 (permalink)
Let's say that I have only one window and I want to select the glass from it in max. How do I do that? Is it possible to select only the glass from my aec Window or will it always remain as a block (frame + glass)?
Thx
t.fzr is offline
file link scale problem mtawheed Autodesk VIZ 1 December 7th, 2005 12:54 AM
Missing: file link manager Sawyer 3ds Max 7 July 6th, 2005 10:07 AM
File Link Problem... demo38 3ds Max 0 April 13th, 2005 10:50 AM
file link manager problems, please help! j_liz Autodesk VIZ 4 April 2nd, 2005 07:42 PM
File Link DWG in max5.1 fatNjazzy 3ds Max 6 June 18th, 2004 10:14 AM
