Old November 29th, 2007   #1 (permalink)
Rendermedia
United Kingdom  Send a message via Skype™ to Rendermedia
Default Importing DWG files,
Hi all,
Is there any reason as to why importing DWG files will create Duplicated Faces in Max,
I have a DWG file that comes in as linked gemoetry, I go to utilities panel in Max and Collapse the file to one editable mesh, then on the Model apprears duplicated faces, even if I weld all the Verts together the duplicate face is still there, as well as this the normals are also sporadically flipped,
I have never used Auto CAD before and so I am trying to find out where the problem could lie so I can fix it,
I have tried weldign verts in Max but the face still sits on top of the other crosshatching as you Navigate in the viewport
Many thanks in advance
Mark
Rendermedia is offline   Reply With Quote
