Name: Sean Ahlquist |
Is there a function in FormZ that performs like the "shell" modifier in MAX. For those of you who aren't familiar with it - the "shell" modifier takes a single surface and makes it into a thickened, closed volume.
Is there a way to do this in FormZ? My expertise is definitely in MAX, but i am teaching a design class and the main platform available is FormZ (the school is MAC based). So, i am trying to ramp up on the functions in the software. thanks, sean |
Name: Brian Kitts |
have you tried the derivatives panel? (right below object type selection). it will allow you to take a surface and pop it into a full solid/ walled solid (go into tool options and you can close/open the bottom and set the widths, etc....
is that what your after? |
thanks for the feedback. that "wall" tool looks right ... i will have to test it out. I'd like to see how it works on fairly complex geometry... if you booleaned a few solids together and then wanted to give it a wall thickness - can it handle all the corners.
phil- is this the same tool that you were referring tool. you mentioned an AVI, but i didn't see anything attached to your post. sean |
Name: Brian Kitts |
sure it will handle all the corners and stuff, but I will make one comment its always best to expand outward- as opposed to inward or using justify center. With the double line tool and the wall tool, if you have a radius with a tight curve and you use either of the tools it can do funky stuff on the inside corners.
Name: erick gustafson |
I'm not sure what version of Form Z you're using but in my version (version 5.5) the "derive parallel surface" tool located in the derivitaves pallete (the one shown in BKittsARC's) works very well and rarely produces bad results. Even more stable than that is the "derive 3D enclosure" tool located in the same pallete.
Good luck! |
| shell material | v-cube | 3ds Max | 1 | May 19th, 2006 09:31 PM |
| Drawing a snail's shell | smoke3dstudio | Off Topic | 8 | December 16th, 2003 04:19 AM |
| Customizing Function Keys | nisus | Painter | 2 | November 30th, 2003 08:07 PM |
| search function | John Dollus | Comments and Feedback | 1 | July 21st, 2003 07:27 AM |
