Old August 16th, 2006   #1 (permalink)
Germany
Post AR light test
hi there,
this is my first post here.itīs a test of cinema 4dīs material and light system,aswell as the GI settings.i have read about how max and vray are the combination of choice for visualisation in this forum alot.since i am using c4d for sometime now and got used to itīs tools and workflow i would like some c&c on this image.this is what came out of the AR in cinema without any photoshop retouch.original render time was about 4.5hrs.
thanks alot
t0ffer is offline
Old August 16th, 2006   #2 (permalink)
STRAT's Avatar
Wales
Default Re: AR light test
not perfect by any means, but a good example of the great quality the AR can produce. nice render. although the 4.5 hour render time is pretty horendous :P
with some optomisation of your settings this scene could be rendered in minutes instead of hours.
STRAT is offline
Old August 16th, 2006   #3 (permalink)
Sindala's Avatar
Netherlands
very nice image! i like it alot. especially the green glow and the spots in the ceiling, but shouldn't the spots be reflected in the floor?
also the light at the back is a bit overbright, but it does give some needed depth to the image!
what was your original output size?
Strat, i'm curious what you mean about the settings. 4,5 hours seems ok to me for this type of lighting
Sindala is offline
Old August 16th, 2006   #4 (permalink)
STRAT's Avatar
Wales
i mean i was curious about his gi settings. a few essential tweeks here and there could literally half the render times. Also, which i'd personally do, is turn the diff depth to 1 (which would save 99% of the render time) and compensate with localised infil omnis. with a bit of fiddling and experience you'd get the same results.
area shadows slow things down to a crawl too.
if this picture is the original output size then 4.5 hours is way over the top imo. also, i'm comming from a dual processor point of view
STRAT is offline
Old August 16th, 2006   #5 (permalink)
Germany
thanks for ur comments,
original output size was 2551*1999,each visible light in the scene is a spotlight source.i used seperate passes for each light to tweak them later in PS.all lights use area shadows(i guess that´s what "flächenschatten" is in english).
it was renderd on a dual opteron 2.4 with 2 gig´s of ram
i am not at my workstatoin at the moment to give u the precise settings,but it´s best AA probaly 400 stochastic ray´s,min 100,max 120 (samples).ray depth 3.will post all settings once i am back
thx
t0ffer is offline
Old August 16th, 2006   #6 (permalink)
NOOXY's Avatar
St Lucia
first off welcome...hope you learn lots of stuff in here..cause i sure did..
your image isn't too bad..you can feel the overall depth of the space..seeing you don't get many post in here from cinema4d i think you did a good job on this one...i agree with strat though with a scene like this and a few tweaks here and there your render time should be cut down in half the time..maybe you can post a scene file so we can work with..just a thought
I had a dream & now it's just another rendered image
NOOXY is offline
Old August 16th, 2006   #7 (permalink)
Germany
thanks, i am sure i will learn a lot around here,once i am back in the office i will see wether i can post the scene file.not sure because of quite large texture sizes for the floor.thx again
t0ffer is offline
Old August 16th, 2006   #8 (permalink)
Sindala's Avatar
Netherlands
the problem i always have with infill omni's is that there are always white area's visible on the ceiling, how do you avoid this?
i just upp the depth to 3 or 4 if needed, and that does give huge rendertimes.
Sindala is offline
Old August 16th, 2006   #9 (permalink)
Germany
i try to avoid omnis for the same reason.in this scene i used spotlights,wich are more precise in control.(inner and outer angle)
t0ffer is offline
Old August 16th, 2006   #10 (permalink)
STRAT's Avatar
Wales
make sure they have specular turned off, and use far clipping instead of falloff. also, use them as ambients instead of diffuses. and if you do get specular blooms on things, use more omnis with less intensity. infact, the more the better really.
STRAT is offline
light test... RamiroB2 Finished Work 11 June 20th, 2006 05:57 PM
vray light hotspot problem! please help ant_sutton VRay Render 4 August 24th, 2005 12:10 PM
Vray; Light Test stylez Work in Progress (WIP) 15 November 4th, 2004 12:56 PM
How to render indirect light only Peppi 3ds Max 3 July 12th, 2004 02:33 PM
3dviz volume light beams through glass? chadsmith Autodesk VIZ 2 January 26th, 2003 07:32 PM
Đ Copyright 2001 – 2008 CGarchitect Digital Media Corp. All Rights Reserved.
