3ds Max Autodesk 3ds Max
Old August 16th, 2006   #1 (permalink)
Default grainy not sure why
any ideas
using scanline rendering with raytrace engine
dnagi is offline
Old August 16th, 2006   #2 (permalink)
bigroo's Avatar
England  Send a message via MSN to bigroo Send a message via Skype™ to bigroo
Default Re: grainy not sure why
Can you post any settings please to assist.
All things in nature are dark except where exposed by the light. Leonardo da Vinci
bigroo is offline
Old August 16th, 2006   #3 (permalink)
jafs00's Avatar
Guatemala  Send a message via MSN to jafs00
check your light source and see whetehr the shadow type are ray traced shadows, if not turn your shadow type to raytraced shadows, and put the bias at something like 0.1 or 0.01
jafs00 is offline
Old August 16th, 2006   #4 (permalink)
hope this helps
dnagi is offline
Old August 16th, 2006   #5 (permalink)
Can you post the settings for the "Advanced Lighting" tab?
-Michael
mmowry is offline
Old August 16th, 2006   #6 (permalink)
no advanced
lighting plug in
dnagi is offline
Old August 16th, 2006   #7 (permalink)
jvlive's Avatar
Name: julius hontarigo
Philippines
can you try changing your antialiasing filter to "catmull-rom"?
the early bird gets the worm, but hey, the late worm missed the bird.
jvlive is offline
Old August 16th, 2006   #8 (permalink)
Fran's Avatar
Name: Frances Gainer Davey
Hi dnagi,
You need to increase the Rays Per Sample in the IES Sky render settings. This will increase render time, so increase in small amounts until the noise goes away. 10 rays per sample might be enough. If this is for an animation, sky shadows may not be feasible.
- Fran
Fran is offline
Faster and less grainy? archkre Maxwell Render 21 April 30th, 2006 02:26 PM
Animation still, too grainy. aflack Work in Progress (WIP) 5 January 13th, 2006 07:07 AM
Extremely Grainy Result in VRay Exterior JamesTaylor VRay Render 6 March 8th, 2005 09:32 PM
