Old December 11th, 2007   #8 (permalink)
BrianKitts
BrianKitts's Avatar
Default Re: Sketchup to Cinema
Originally Posted by STRAT View Post
do you have autocad? if so, explode the entire model first, then import into autocad, then 3ds it to cinema from autocad. (or another cad package) SU to cinema isn't the best solution.
this may be the dumbest question I have ever posted..... but how do you export a .3ds from autocad? I've never attempted it before, and the the usual suspects of doing a "save as" or "export" under the file menu for autocad2008 don't show .3ds as an option.
and I'm not seeing anything about in the help files..... it tells you about import, but no export...
am i nuts?
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline   Reply With Quote
