3ds Max Autodesk 3ds Max
Old August 16th, 2006   #1 (permalink)
maxkid's Avatar
Canada  Send a message via Skype™ to maxkid
Red face rendeing hi-res aerials
Hi guys,
I am working on max7 ,trying to render a hi -res aerial photo ,it is 40 mb file ,i also croped it and got it to 10 mb size still it gives memory error in 3dmax7 ----any idea how do i deal wit this aerial map
1) it is aerial jpg image with 12,947 by 23,729 pixels i got this down to
7,540 by 15,000 pixels ,still it does not
render......it give error satinbg not enough memory ,my mchine has 1 gb ram and mora than 10 gb hard disk free......
wonder if you could give any idea or feedback................
cheers,
maxkid
maxkid is offline
Old August 17th, 2006   #2 (permalink)
Default Re: rendeing hi-res aerials
I would try to lower the dpi of the aerial. (Not sure if this is what you did to reduce the size originally) Also make sure the aerial is in a jpeg format, that will compress the size some. 40 mb is a huge file, I've never seen any photo that big before.
Good luck
frank1331 is offline
Old August 17th, 2006   #3 (permalink)
Maxkid, are you using this iamge as a map, or a background?
If you are using as a background I would slap a low res version 200x400 into max and then replace with the high res version in post. If you are using as a map than you may have to do some juggling, breaking the image apart and using a blend material between low res and high res pieces of it - based on how close you get to various parts.
A file of that resolution is not going to be friendly to your machine or your render times.
Jon Kletzien
StudioAMD Inc.
Website
jkletzien is offline
ultra high res rendering STRAT General Discussions 34 May 10th, 2006 07:32 AM
starck furniture mid/low res nazcaLine 3ds Max 5 October 28th, 2005 07:39 AM
need high res trees frank1331 3ds Max 7 July 20th, 2005 11:35 PM
Free Hi res Landscape images? JamesTaylor General Discussions 2 March 9th, 2005 07:32 AM
high res brick tex with a lot of bricks DennisHolland General Discussions 8 January 14th, 2005 08:26 AM
