Old December 14th, 2007   #1 (permalink)
vismagine
Name: Christian da Silva Caetano
Germany
Default How do YOU model your buildings?
Have you ever asked yourself if there is a better or faster way to model complex 3D building geometries than the way you use to model them. There are so many possibilities to start a modelling process for architecture and you have to decide which one works best to save time and money.
Some of you may model your exteriors or interiors directly in construction software tools like Autocad, Revit, Archicad or other tools that offer architectural features. Others start with simple 2D construction lines and try to build the model from there. How is YOUR work flow for efficient building modelling?
To make the best decision it is necessary to know all the work flows that are used in praxis to reach the approach. For this I would like to start a little discussion and try to answer some of the following questions:
+ How do you usually start to model your buildings?
+ Do you have different work flows for different approaches?
+ Do you use spline/loft techniques, polygonal box modelling?
+ Has someone ever used nurbs to model building and what where the experiences from that?
+ Which work flow appears the efficientest in practice?
+ Which tutorials on this topic do you advise?
Could be an interesting discussion for all of us – so I hope for a large participation on this topic.
Cheers,
Christian
vismagine is offline   Reply With Quote
