3ds Max Autodesk 3ds Max
Old August 21st, 2006   #1 (permalink)
maxkid's Avatar
Canada  Send a message via Skype™ to maxkid
Question make preview problems in 3dmax7
Hi guys,
Wonder if you could help me here ,I have got a file which is 60mb - when I do make preview to see my camera animation ,it skips frames while previewing - so when i see my quicktime movie of this hardware render it shows some of th frames as blank........!!!!!!!
well i really do not why!!!!!!!!!
1) my machine - had more than 10 gb free hard disk and 1 gb ram it is HP 2.7 mgz machine ,it works fine.
2) in my main file i have xref 3 other files and even if i merge them that would make them 60mb it still SKIPS THE FRAMES WHEN YOU MAKE PREVIEW COMMAND.
3) I tried previwing in a different machine which is dual xeon ,but i am getting the same problem.
4) i tried changing my vieport settings , choose different driver etc but still same problem
5) my scene contains only geomatry -polygons and camera animating.
6) it is about 1800 frames at 15 fps speed.
any ideas coments -tips would really HELP.
cheers,
maxkid is offline
Old August 22nd, 2006   #2 (permalink)
England
Default Re: make preview problems in 3dmax7
have u altered any settings in the make preview window? what is your frame rate settings in this window?
also, 15 fps is kinda low, for a smooth animation id have atlease 25 fps.
deano!
Pikcells Animator, Modelling & Environment Designer
notamondayfan is offline
Viz 4 Crashing problems Showcard Autodesk VIZ 4 February 15th, 2007 03:20 PM
Snap and Pan problems Sergio 3ds Max 5 February 9th, 2006 10:18 PM
viz 2006 - make preview rmoore97 Autodesk VIZ 1 January 11th, 2006 03:45 AM
'Make preview' not working! dbarc 3ds Max 5 September 24th, 2005 01:22 PM
3 problems Jeenyus203 3ds Max 7 February 25th, 2004 04:56 AM
