Old August 24th, 2006   #1 (permalink)
Default Vray Distributed rendering Setup problem
Hi,
I am using Vray 1.5 and Max 8.
I tried to use Distributed rendering with another computer thats available with me.
But when I start the vrayspawner80.exe the vraydummy60.max is not stable. It closes off.
Can anyone help me in this please :-)
Thanks in advance
Rap
3rdaxis is offline
Old August 25th, 2006   #2 (permalink)
Ireland
Default Re: Vray Distributed rendering Setup problem
Are you sure it doesn't just minimise down to the windows bar at the bottom of the screen ?
If it does and reads 'vrayspawner80.exe' all is fine. You can't maximise the spawner as you would with max.
Noise is offline
Old August 25th, 2006   #3 (permalink)
bigroo's Avatar
England  Send a message via MSN to bigroo Send a message via Skype™ to bigroo
Question Re: Vray Distributed rendering Setup problem
Originally Posted by 3rdaxis
Hi,
Thanks in advance
Rap
Are you trying to start the spawner on the client or the server?
All things in nature are dark except where exposed by the light. Leonardo da Vinci
bigroo is offline
Old August 28th, 2006   #4 (permalink)
Hi Birgo and noise,
Thanks for your replies. I am trying to start the Spawner80.exe in the server machines. Once I start the spawner80.exe its start the Vraydummy.max but its not stable the max application closes once it appears in the task bar. Wheresas in another machine when I tried the same its the vraydummy.max stay in alive in the Task bar.
Can you please clarify for me why the vraydummy.max is not alive in the1st computer.
Rap
3rdaxis is offline
Old August 28th, 2006   #5 (permalink)
kippu's Avatar
better to ask chaosforum people...they have better ideas
www.renderviz.com
kippu is offline
Old August 29th, 2006   #6 (permalink)
bigroo's Avatar
Kippu's right, Vray produces a comprehensive log file which can be sent to them for a speedy answer.
bigroo is offline
Vray Glass Problem Hallock VRay Render 8 June 14th, 2006 08:37 AM
rendering problem using Vray tanni VRay Render 11 May 31st, 2006 11:33 AM
Newb Vray Exterior Setup MegaPixel VRay Render 6 April 10th, 2006 01:06 PM
vray light cache as secondary bounce doesn't work with distributed rendering d7man2000 VRay Render 4 February 21st, 2006 06:26 AM
vray light hotspot problem! please help ant_sutton VRay Render 4 August 24th, 2005 12:10 PM
