Thread: XREF Materials
Old December 23rd, 2007   #1 (permalink)
JamesTaylor
Default XREF Materials
XREF Materials
The ability to "XREF" materials into a scene from a central library, so that when a material is updated the update appears in the material across multiple files rather than only in the current file.
in situations such as creating images for housing estates, where up to 20 different images need to be generated, scenes can end up being very large with many polys in one file which can drastically slow certain processes down such as panning and rotating viewports. On the flip side having the entire estate and all house types in one file allows a single material to be created per brick type for example. If this material is updated in the material editor it is reflected across each piece of geometry it is applied to.
If a material could be "XREFed" into a scene, large scene could be broken down into smaller files that are easier to manage, whilst still allowing a "master material" to be used in each individual file for repetitive elements such as bricktypes that will be the same across the entire set of images.
JamesTaylor is offline   Reply With Quote
