Originally Posted by Spooner04
Rick's method sounds much easier. How easy is it to modify afterwards?
Actually it is very easy. Once you have a clean quad mesh, you can do pretty much whatever you want on it. I normally use shape merge to creat the roads and stuff, although there was an oldo plugin called Glue (or something like that) by the same guys who did Forest Pack that could create a line's projection on a mesh quite easily. Not sure it still exists, but I'll check it.
Update: Yes, it still exists.
Here it is (and it's still free!)
