Old August 26th, 2006   #1 (permalink)
Cool Vray - How to exclude objects from Reflection ??
Hi fellows....
i am doing a product animation. i have been doing arch viz stuff from years, so this is something new to me.
i am using some self illuminated planes above the black object so that it can reflect on it.
but the problem is that my ground plane is also reflecting those self illimunated cards. i don't want to reflect those white self illimunated cards on the ground.
so is there any tips abt how can i exclude the reflection of the white self illimunated cards from the ground plane ???
too bad vray material doesn't have reflection exclude/include objects option, wich is do available with max raytrace map
i think this is a noob question
Cheers fellows !!!
Passion is the flame that burns forever
vishesh_12 is offline
Old August 26th, 2006   #2 (permalink)
Default Re: Vray - How to exclude objects from Reflection ??
Assuming you still want the model to reflect in the ground plane ....Move them out of the cameras view ???
IGD
imgumbydammit is offline
Old August 26th, 2006   #3 (permalink)
Brian Smith's Avatar
You can exclude reflections, it's not a vray issue though. Right-click the object, select Properties, and deselect Visible to Reflections/Refractions.
Brian Smith
www.3dats.com
Brian Smith is offline
Old August 26th, 2006   #4 (permalink)
thanks for the suggestion fellows
>>> imgumbydammit ........
i have tried many other things but nothing work. finally i did as u said. i linked the self illuminated plane with the camera so it moves with the camera. the idea is to position the self illuminated plane where it won't get reflected on the ground plane.
i am now able to get rid of its reflection on the ground. it works mate
>>> Brian Smith...
but the problem is that i want the self illuminated plane to get reflected in the black product.
if i do what u said than it won't be reflected in the black product too. thats a problem for me.
Old August 26th, 2006   #5 (permalink)
OK I follow your problem. But why not just create a VRay light (plane), and either exclude it from illuminating the the plane object or just use the material settings to make the plane not show such specular highlights and the black object to show specular highlights.
Brian Smith
www.3dats.com
Old August 26th, 2006   #6 (permalink)
Christopher Nichols's Avatar
In the new 1.5, if you right click on the object and pull up the Vray Properties, you can select visibile in reflection and refraction independently.
Christopher P Nichols
Old August 27th, 2006   #7 (permalink)
Brian Smith >>>> But why not just create a VRay light (plane), and either exclude it from illuminating the the plane object
i have tried that. Vray can only include or exclude the objects from illuminating or from casting shadows. this feature of vray light has no effect on reflections. objects will be reflected whether or not they are included in the include list of objects in Vray light properties.
i tried that too. it works actually.
i added a omni light with only specular highlight option enable. here i am trying to make the black object look glossy but without affecting the ground plane.
i removed the white self illimunating plane as its required, otherwise it will again get reflected on the ground plane. so i am trying to replacing the white reflections on the black product with the specular highlights.
i was able to get the specular highlights only on the black product and not on the ground plane. so it works !!!
but i have also noted that the specular highlights that i got was not looking as great as the effect i was getting from the reflection. so thats why i haven't used this method
another thing to note here is the white area u see on the ground plane [ in the above picture ] is the reflection of the self iluminating plane above. its not specular highlight.
>>> Christopher Nichols
thats cool.
looking forward to get my hands dirty with new Vray 1.5
fellows... here is the animation what i have made so far...
click on the thumbnail to download the video 1.3 MB [ DivX Codec Required ]
any tips / suggestions for improving it are welcome
Vray - Proxy objects and Distrubted Rendering? JamesTaylor VRay Render 18 November 24th, 2008 12:25 PM
VRay Kitchen : Glass reflection problem? purnomo_adi Work in Progress (WIP) 5 May 26th, 2006 12:42 PM
using a dome to cast reflection in vray ecastillor VRay Render 1 September 8th, 2005 11:18 AM
Vray reflection question. Tommy L VRay Render 1 August 3rd, 2005 08:51 AM
vray: no gi with reflection virses VRay Render 6 October 8th, 2004 09:25 AM
