Old January 2nd, 2008   #3 (permalink)
DavidR
Default Re: make poly and mesh panels (including shortcuts) identical
Originally Posted by Rick Eloy View Post
I'm not a specialist, but I think that this is because mesh and poly are not the same thing, not only their names are different. Meshes are created by any 3d app, while polys are a 3ds max thing. You probably won't get them to look nor work the same.
I know they're different in a couple of ways, but the panels can and should have the same layout, because mesh and poly are very, very similar: both have the exact same sub-obj selections, both use the same modifiers and otherwise bahave almost exactly the same way. Btw, polys are also created by almost any 3d app, except for CAD programs -I'm not sure I understand your point in mentioning this?
DavidR is offline   Reply With Quote
