Old August 28th, 2006   #1 (permalink)
pradipta's Avatar
India  Send a message via MSN to pradipta Send a message via Yahoo to pradipta Send a message via Skype™ to pradipta
Default Problem with vray and backburner
I am facing an unique problem with vray network rendering. i am using 3dsmax 8 and vray 1.47. in rendering server vray is not rendering the final render after calculating the LC and IR map passes. What can be the reason behind this? while rendering on single machine the rendering is coming as usual. Thanks in advance for any advice.
"There is no possibility of cheating in art. It is either good or bad."
Portfolio
3DAllusions
pradipta is offline
Old August 28th, 2006   #2 (permalink)
BrianKitts's Avatar
Default Re: Problem with vray and backburner
although this wouldn't explain why it would work local and not over the network..... make sure you have the tick box off for "do not render final image" in your global settings...... thats the first thing that comes to my mind.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old August 28th, 2006   #3 (permalink)
pradipta's Avatar
Brian, i have not checked the "do not render final image" in render setting. i rendered the same file with same rendering setting on standalone machine, and it is rendering. i kept all the textures in the individual machines and output files are also getting saved in the respective machines. i have no clue why this is happening. Thanks Brian for your response.
Portfolio
3DAllusions
pradipta is offline
Vray Free + Backburner Bugga_Guy VRay Render 1 August 26th, 2006 04:06 PM
vray with backburner Munz VRay Render 9 July 17th, 2006 05:53 AM
vray rendering animation with backburner keeps rendering 1st frame d7man2000 VRay Render 3 February 21st, 2006 01:02 PM
vray dr vs. backburner Timothy Saunders VRay Render 20 November 30th, 2005 01:57 PM
Missing Vrender50.dlr Message (Not a Vray User) MegaPixel 3ds Max 9 August 5th, 2005 08:10 PM
