| Realtime/VR/ Interactive/ VRML Discuss anything related to VR and Architecture here. |
Hi all,
What viewer do you use for panoramic images? I'm looking for an easy workflow to render and use panoramic images so our clients can pan/zoom. What do you recommend? rgds, nisus
How can these images/viewers be shown on a webpage?
nisus
Name: Dean Punchard |
i dont know what you mean exactly. do you mean like 360 quick time movies, where you click and drag so it appears like you are rotating on the spot?
if so check this out http://plugins.marclorenz.com its a plugin for max, and is the easiest thing ive ever used, and has pretty good results. or do you mean like you have a single image, but really wide panoramic shot? almost too wide to view on screen? if so, you'll prob need some interactive web application, such as flash. try looking through www.flashkit.com. hope that helps, deano!
Pikcells Animator, Modelling & Environment Designer |
Hi Dean,
Tnx for your quick reply. I meant the 360 degrees images. I'll check out the link you gave me. In the mean time I've found that max has a renderer and exporter. Pitty is, it doesn't seem to work with network rendering. Any one got a clue on how to surpass this? Tnx nisus
Well, yeah... but I would prefer to render out the files in the network, so my workstation can be used for other stuff... Also, the panoramas render 6 images (every face of a box), which is faster with 6 machines ,-)
So any tips are welcome ,-) nisus
you need quicktime and if u save them as *.mov ... which is what everyone does more or less
if you have jpgs then you need to convert them to .mov which can be done by pano2qtvr... some stuff here http://www.renderviz.com/panorama |
Name: Chad Warner |
If you have Vray, you can render a spherical camera to the network, then use the resulting image as your environment map. Otherwise, maybe there's a plugin out there that will allow you to create a spherical camera?
MR can render spherical camera, but Max can do the panorama's itself too ;-)
| Please Read This Before Posting Images | Rick Eloy | Finished Work | 31 | March 15th, 2008 08:20 AM |
| Please Read This Before Posting Images | Rick Eloy | Work in Progress (WIP) | 3 | August 28th, 2007 04:31 PM |
| NEWS: ARTVPS Launch new Rendering Solution with Mental Images | Jeff Mottle | SIGGRAPH 2006 | 0 | August 1st, 2006 10:41 PM |
| Hammersmith Pumping Station - Interior Images | hrauklaura | Finished Work | 2 | January 25th, 2006 06:30 AM |
| Linking to thumbnail images | Jeff Mottle | Comments and Feedback | 7 | March 16th, 2004 03:08 PM |
