Old August 29th, 2006   #1 (permalink)
Default Leather material
Im just aiming at leather here, no other material.
Wich one would you go for?
Maybe non of them .
Difference is only in bump width.
Advice please.
Beeeee!
del82 is offline
Old August 29th, 2006   #2 (permalink)
England
Default Re: Leather material
make the texture darker. leather is usually a lot darker, almost black (so long as your going for black leather).
Pikcells Animator, Modelling & Environment Designer
notamondayfan is offline
Old August 29th, 2006   #3 (permalink)
Ky Lane's Avatar
Personally, your reflections are WAY too sharp. Diffuse the crap out of them.
Ky Lane is online now
Old August 29th, 2006   #4 (permalink)
almost black
Emmmm, no I was trying as hard as I can to get white leather
Beeeee!
del82 is offline
Old August 29th, 2006   #5 (permalink)
England
well in future it might be worth stating that in your origional post.
Old August 29th, 2006   #6 (permalink)
...or opening your eyes
Beeeee!
del82 is offline
Old August 29th, 2006   #7 (permalink)
England
Maybe non of them .
Advice please.
where does it state white?
Old August 29th, 2006   #8 (permalink)
What abouth these two?
I also changed the model a bit.
Beeeee!
del82 is offline
Old August 29th, 2006   #9 (permalink)
England
ok.
attached is a texture i use for my leather furniture. also use it as a base for bump maps. im sure you could change the colour of it in PS to your desired tone.
as for bump mapping leather, leather is usually really flat, so little bump required.
hope this helps.
Old August 29th, 2006   #10 (permalink)
richmondlu's Avatar
To much specular light comming off the leather most leather is a matte..
i will post example after work
richmondlu is offline
shell material v-cube 3ds Max 1 May 19th, 2006 09:31 PM
mr problem with glass mr material with dielectric msamer 3ds Max 9 April 6th, 2006 11:34 AM
Leather Material MrCAD 2D/3D Tutorials 4 January 13th, 2006 10:29 PM
Chrome material problem evanmoses VRay Render 18 March 16th, 2005 09:12 AM
