Old August 29th, 2006   #1 (permalink)
Ky Lane's Avatar
Default Odd glow...
Hi again guys,
Being the idiot I am, I have been using sparsely placed omni's to brighten up my rooms, instead of using vray lights. DUH...
Anyway, Ive converted my model and seem to be getting some nice results, however Im getting an odd "glow" up from my tiled floor, which, for the life of me, I cant understand why.
I have a free spot above the area, with exponential decay, so it shouldnt be bounced light from the spot...just seems weird...
Any hints?
Ky Lane is offline
Old August 29th, 2006   #2 (permalink)
Default Re: Odd glow...
usuall happens durin test renders.. goes away when u do higher reso renders with higher irr settings.
u might wanna chek ur antialiasing n color mapping settings too.
usually stick with mitchell netravali n exponential consc.
u can experiment with all of em n suit ur need
blade911 is offline
Old August 29th, 2006   #3 (permalink)
Ky Lane's Avatar
Cool. It is a very low test render....see how the higher end goes overnight tonight. Cheers.
Ky Lane is offline
Old August 29th, 2006   #4 (permalink)
Fran's Avatar
Name: Frances Gainer Davey
Hi Ky,
It looks like your IR map settings are too coarse for the size of the image. If you saved the cache, try rendering it at 800x600.
Also, GI blur == bad. Just in case you were using that.
- Fran
Fran is offline
Old August 29th, 2006   #5 (permalink)
Ky Lane's Avatar
Cheers. Left it to do a 5000x3000 render overnight. Soon see
Ky Lane is offline
Lens glow mac_n_ric 3ds Max 1 August 31st, 2005 08:22 AM
how do I make an object glow Munz 3ds Max 5 July 18th, 2005 01:07 PM
light glow effect Brian Cassil Photoshop 8 April 26th, 2005 01:23 PM
Glow Effect Jonny English 3ds Max 6 July 29th, 2004 03:09 AM
