Old December 12th, 2003   #1 (permalink)
Ken Walton's Avatar
After posting my "need help" topic for fR, mental Ray, and max's Advanced Lighting options - the most efficient and simple setup is this ring technique posted by DelfoZ. I used these boxes as a test stand-in for a condo complex that's going on this land. Render time - 3 seconds - on a dual 2.4 Xeon/1 GB Ram/Nvidia Quadro 4 900XGL; Max 6 scanline renderer - no advanced lighting. I'm pretty happy with the results (although this is my first try at a true exterior - I probably don't know where to find the faults and discrepancies - please help...)
http://www.cgarchitect.com/forum/fil...e=render_1.jpg
Thanks,
Ken Walton
"Under certain circumstances, profanity provides a relief denied even to prayer." - Mark Twain (1835-1910)
Ken Walton is offline
Old December 12th, 2003   #2 (permalink)
DelfoZ's Avatar
Mexico Send a message via ICQ to DelfoZ Send a message via MSN to DelfoZ
to be ur first test , r good. .
if u r using 3 rings try to change ur bottom ring for a target direct.. and keep it less bright...
[ December 12, 2003, 11:18 AM: Message edited by: DelfoZ ]
DelfoZ | DS
Citta Nouva
DelfoZ is offline
Old December 12th, 2003   #3 (permalink)
Ken Walton's Avatar
Question
Thanks man - what do you mean by "button ring"?
Old December 12th, 2003   #4 (permalink)
Brian Cassil's Avatar
I think he means bottom ring.
"writing notes is quieter."
Brian Cassil is offline
Old December 12th, 2003   #5 (permalink)
DelfoZ's Avatar
Upps... Err. Yes. bottom Ring.
DelfoZ | DS
Citta Nouva
DelfoZ is offline
