Name: Daron Pardine |
I just got the Logitech Cordless DesktopS 510 keyboard + mouse package and am somewhat satisfied with everything exept the way the mouse wheel (with the shite "tilt wheel" feature) can't be used like a traditional "dumb" mouse wheel to pan and zoom extents in acad or max.
I've tried messing with the software to change the settings of the mouse wheel but nothing gives me the old-fashined pan function when clicking the wheel and dragging. Is there a software out there that will correct this issue? thanks note: mbuttonpan = 0/1 ... doesn't change anything Last edited by tecton3d; September 3rd, 2006 at 12:11 PM. |
there is a utility provided by Logitech but the "universal" scrolling function still fails to make the "wheel click and pan" work. when I scroll with the wheel it zooms in and out ~ that's ok... but when I click the wheel, it always initiates the horizontal scroll... annoying.
I'll just use my good old mx310 until I can dig up a fix. thanks p.s. how do you like that Razor? ... looks nice and light : ) |
The Razer is great. I have it cranked up to 1000MHz and 1600DPI and compensate by turning down Windows acceleration, which makes for very accurate and non-jumpy mousing. I also got a Razer Control mouse pad. (Sorry, now they're called "Precision Mousing Surface".) It's enormous, which I like.
BTW, cranked up the CPU a bit more |
your mouse sounds like a Ferrari : )
I have an Xtrac Zoom pad and it's alright unless your hand makes a little moisture on the pad then it's like you're dragging the thing across flypaper ~ not an ideal situ for a mousepad. that's great with your E6400 Conroe... the more I think of it, the more I'm tempted so just keep on posting those wicked benchie #'s and I'll cave and buy a setup soon enough hell, I'm actually thinking of selling my dual optie workstation and 4 oc'd xeon nodes (mobo's ram cpu's hsf's and extra cpu's) in order to get 2 6300/6400 conroe rendering rigs in addition to a new 6600/6700 workstation... that's an awful lot of parts swapping but may be well worth it |
I wouldn't even recommend bothering with the 6700 - I can't see it being worth the extra money considering how fast you can get a 6400 or 6600 to go. I can see a 6600 being worth it for the extra cache. Get some 975 MB and 400MHz RAM that specs above 2V, I've seen people with slower RAM have issues when going into the high 300 range.
I keep wanting to take the clock on this higher, but there's got to be a limit and I must be pressing my luck, though it shows no signs of trouble. BTW, render time on that scanline teapot scene is 4:39 at 2960MHz, but I don't know how useful it is a benchmark, since it spends so much time calculating raytrace maps which doesn't use the full multi-CPUness. Also, I'm staying in 32-bit Windows because I'm not happy with the software support in 64-bit yet, but when it gets a bit better I'll upgrade. |
#8 (permalink) | |
yeah, if that scene is non-smp favored it's kinda rubbish to use it as a benchie... a simple scene with a couple million faces and full GI would do the trick to get those buckets turning over. what exactly are you having trouble with x64? I've almost bought in several times but haven't for this exact reason?? Mabe Vista will provide some 64bit relief. |
#9 (permalink) | |
what HSF/case cooling are you using? If you could stand more fan noise, you may be able to go a bit higher, but nobody wants to sit next to a computer that sounds like a hairdryer |
Some glitchy drivers, the utils I wanted to use for monitoring the OC didn't function, my Norton stuff didn't work... actually, not very good reasons, but with the OC'ed MB I wanted the environment and utils I was most familiar with. I'll have another go if I start getting into files that suffer from lack of 64-bitness, but considering I've now got a higher Cinebench OpenGL score than I've ever seen before I don't know what it would take to do that.
| Max 7 affects my mouse speed | ITryMyBest | 3ds Max | 2 | June 1st, 2006 05:16 PM |
| New mouse design, are you interested? | rich | General Discussions | 10 | April 15th, 2005 11:33 AM |
| Zoom with mouse wheel | JHalton | 3ds Max | 2 | November 19th, 2004 06:13 AM |
| zoom with mouse wheel | markf | AutoCAD/AutoCAD Architecture | 1 | August 11th, 2003 10:52 AM |
| Mouse wheel | STRAT | AutoCAD/AutoCAD Architecture | 4 | March 14th, 2003 07:13 PM |
