Old September 6th, 2006   #1 (permalink)
Default 3GB Switch Video Card Issue
Hi all -- just flipped the 3GB switch last night and it has had a negative impact on my video card. I know I have read about this problem before when using the 3gb switch, but I can't seem to find a solution for it now. Is it a driver issue, is there a work-around?
Any help is appreciated. Thanks!
thickly is offline
Old September 6th, 2006   #2 (permalink)
Ray
Ray's Avatar
Default Re: 3GB Switch Video Card Issue
I've noticed that the 3GB switch is not compatible with the sli on my laptop--it's one or the other. Not sure what kind of trouble you are having, though.
Ray is offline
Old September 8th, 2006   #3 (permalink)
jow
have alook here-
http://support.microsoft.com/?kbID=810371
I had problems before, booting up and windows not seeing my Gfx card, thought it was a Gfx driver update i'd made (release 90 nvidia) but turned out it wasnt.
Changed the boot.ini file to read-
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional 3GB" /3GB/Userva=2900
Works fine now
jow is offline
Old September 10th, 2006   #4 (permalink)
after a couple of restarts it seems to have worked itself out -- just one of those unexplained things that I don't mind not knowing the answer too, I'm just happy it works.
thanks
thickly is offline
Video Card Reccomendation jtseaman Hardware and Technical Discusions 10 March 28th, 2006 04:41 PM
Video Card Question trhoads Hardware and Technical Discusions 11 February 17th, 2005 02:59 PM
No Video Card Fast enough to run ADT?! Aspiring Visualizer! Hardware and Technical Discusions 3 October 24th, 2004 06:54 PM
Video card problem azazel61 Hardware and Technical Discusions 3 May 31st, 2004 11:25 AM
