Originally Posted by NOOXY
nice work mate...can't wait to see finals...whats the time frame and rig setup on your renders
Sorry for the delayed response as I've been busy working on ther projects.
If you're refering to the lighting rig. It look about 5-10 minutes to get the lighting in place and set the correct exitance values. modo has an interactive render preview (iView) so it does not take long to get the lighting where you want it.
In terms of the lighting I often use a combination of Area Lights and Luminous Geometry. I use these two light types together (at each location, same size) to get the best of both worlds in that I get smooth highlights from the luminous geometry and great soft shadows from the area lights. This is very simple and fast to setup in modo.
-neil
