Pan with Roller Wheel
Pan with Roller Wheel on mouse while in a commandm
Many applications such as AutoCAD and Sketchup allow you to draw a line (or do another command) and while you are still in that command, you can pan by pressing down on the roller wheel. That is how you pan in Max too. However, it sucks that in Max, if you are in a command, like drawing a line for instance, and if you try to pan by pressing in on the roller wheel, you are kicked out of the command. Why would that have ever been part of the programming?
Because i is WAY faster than pressing "I" to move around as you are zoomed in an area, or zooming in and out as you draw lines.
