Old February 2nd, 2008   #7 (permalink)
johnvid
Default Re: tired of getting the right settings
If you have read all the LWF tutorials, and also tried adjusting the brightnes of the sun/sky (depending on which version of vray, values below 0.1 or 0.07), also make sure your not double gamma adjusting, make sure your rendering unclamped images, and yes it helps to know about ISO & fStops & Shutter Exposures
But even with a max camera, if you render floating point images you can still adjust the exposure later.
johnvid is offline   Reply With Quote
