| Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications. |
Name: Tim Smith |
Hey Guys,
I am trying to complete a script in 3dsmax and I want to use the legacy import command for .dwg files. The problem that I am having is all of my layers (ie. "siding") are being imported in to max as ("Layer:siding"). this happens because the default import command is newer and adds "Layer:" to the front of all layer names. I am trying to find a way to use legacy import, when I manually import using legacy import the names come in the right way. But there does not seem to be a way to assign the legacy import through scripting. here is what I have : theClasses = importerPlugin.classes importfile "x:\IL_Jobs\models\Aberdeen-c.dwg" #noprompt theClasses[4] Your help would be greatly appreciated. Thanks TS |
Name: Anton Vasilescu |
Max sees only one importer which is the new one and it doesn't allow access through mxs to the legacy one. I've had the same issue and solved by removing the plugin for the new importer from the installation directory...
Anton Vasilescu - Freelance Artist Modeling/Animation/Scripting/Motion tracking/Rotoscoping http://www.75ive.com |
| MAX Script for replacing geometry in an imported DWG file? | jonssonhenrik | Scripts | 1 | June 26th, 2006 07:32 AM |
| Dwg to max import problems | 3dfreelancer | 3ds Max | 4 | January 31st, 2005 07:49 AM |
| More CAD tools? parallel line, spline dwg import, tip | PellePixel | 3ds Max | 1 | July 8th, 2004 01:41 AM |
| Autocad dwg import | Tiny Piney | Autodesk VIZ | 2 | October 22nd, 2003 08:18 AM |
| How to import CAD dwg to lightwave? | blaz | Lightwave | 33 | May 11th, 2003 08:03 PM |
