Old September 18th, 2006   #1 (permalink)
Default glass not allowing HDRI lighting through
double sided volume with VRAy material, near 100% opacity, transpearency selected under fog parameters, fog color set to white.
No light is coming through from the HDRI, although the direct light used for the sun is. Anyone else have this issue before?
Jefferson Grigsby is offline
Old September 18th, 2006   #2 (permalink)
Default Re: glass not allowing HDRI lighting through
watching thread
DavidR is offline
Old September 19th, 2006   #3 (permalink)
FlytE's Avatar
Name: Andy Pennington
Scotland
Off the top of my head:
Is affect shadows and affect alpha ticked? A temp solution would be to go into the properties of the object and turn off 'cast shadows'. It might also be because caustics needs to be enabled?
"How many polygons does the real world push?"
FlytE is offline
Old September 21st, 2006   #4 (permalink)
no, we can not figure it out. I have evrything checked the way it should be, this is very confusing. It is somebody else's model, not ours.
Lighting through glass walls in archicad? Sambo Archicad 0 April 26th, 2006 10:34 AM
Lighting with HDRI tmccarter VRay Render 1 January 11th, 2006 01:23 AM
glass and lighting argie_uk Work in Progress (WIP) 4 October 21st, 2004 11:55 AM
new challenge about hdri lighting and reflections... seismograph The Unchallenge 21 June 8th, 2004 07:50 AM
