Old September 18th, 2006   #1 (permalink)
bully712's Avatar
Exclamation Paper space scale change
I'm using ADT 2004. I need to change the paper space scale from 1/8" to 3/32" How do I change this? This is an urgent request so any help will be appreciated..
wireboxdesign.com
rendering the imaginative
bully712 is offline
Old September 18th, 2006   #2 (permalink)
Brian Smith's Avatar
Default Re: Paper space scale change
I don't have it open in front of me to verify but I'm pretty sure all you have to do is double-click a viewport and select a standard scale from the Properties dialog box...of course you have to be in architectural units first.
Brian Smith
www.3dats.com
Brian Smith is offline
Old September 19th, 2006   #3 (permalink)
alikashan's Avatar
Pakistan  Send a message via MSN to alikashan Send a message via Yahoo to alikashan Send a message via Skype™ to alikashan
Thumbs up Re: Paper space scale change
if i remember right click inside you viewport mv then
zoom=3/32*12xp that is the command thats all. because your 1/8 scale is
zoom=1/8*12xp=1/96xp...................
may b it helps
Ali Kashan
Stranger than LIfe......... but Still Learning
alikashan is offline
Old September 19th, 2006   #4 (permalink)
TheAllusionist's Avatar
In ADT you should just go up to Documentation drop down menu and set drawing scale option. This adjust various settings like text. As outlined above the other techniques set the viewport scale. If you are really talking about setting the scale of text and linetypes for entities in Paper space then go full scale and set your ltscale to 1 and toggle psltscale on by choosing '1' instead of '0'. This is all off the top of my head and for earlier versions of ADT so I could be off a little but that is what I remember from back when I used ADT 3.3
The Opinions Expressed Here Do Not Necessarily Reflect Those of a Rational Mind.
3DAllusions | 3DAllusions Studio | MrMaterials
TheAllusionist is offline
Paper Space eddie57 AutoCAD/AutoCAD Architecture 25 June 20th, 2006 09:37 AM
ArchiCAD to 3DS Scale Issues kaylmyers Archicad 2 June 22nd, 2005 03:25 PM
Paper space mark68 AutoCAD/AutoCAD Architecture 5 December 13th, 2004 12:09 PM
Paper Space zoom issue Sawyer AutoCAD/AutoCAD Architecture 3 August 25th, 2003 06:59 AM
