Old September 20th, 2006   #1 (permalink)
Singapore
Default 3d people collection URGENT!
Hi there
I am wondering whether anyone has tried 3D models library from http://www.proviz3d.com, and http://www.archivision.com
The cost different is huge and if anyone out there has experience, please send some thought
Rgds
WT
wturner_99 is offline
Old September 20th, 2006   #2 (permalink)
chuck's Avatar
Default Re: 3d people collection URGENT!
the proviz ones are animated poorly and they don't look that good. they don't need character studio, but they do look unnatural. i couldn't find 3d models on the archivision site.
i really like the look of the aXYZ products. you can get still packages or animatable ones that use motion capture data that looks correct in an animation...
http://www.axyz-design.com/
chuck is offline
Old September 20th, 2006   #3 (permalink)
Singapore
Hi Chuck
Thanks for your info. I mistyped the link, it was supposed to be: http://www.archvision.com. They have some 3D collection there although the cost is substantially higher than http://www.proviz3d.com
The axyz collection is very good although the price of is higher than proviz3d. Any other alternative beside axyz with the same price range as proviz3d?
regards
WT
Old September 20th, 2006   #4 (permalink)
Maxer's Avatar
The AXYZ people mostly look like monsters when you get to close to them. They don't work in every situation and I would only use them when they are far enough away from the camera to hide their weird looking faces. RPC's are the best all around solution that is out there at this time.
“There is no spoon”
Maxer is offline
Old September 20th, 2006   #5 (permalink)
Singapore
Is RPC good for high resolution rendering?
And if anyone has time, please compare between these websites:
www.proviz3d.com, www.got3d.com, www.lowpolygon3d.com
I will make a purchase by this week
Your help is greatly appreciated
rgds
WT
Old September 20th, 2006   #6 (permalink)
BrianKitts's Avatar
RPC is a substancial resolution that you can get away with them at a decent size. If you are going really high res with them up close, they have a high resolution library if I remember correctly.
But you also have to be aware that they can do funny things sometimes, specially when rendering with GI. Sometimes you have to be a little selective to what RPC's you use so that they fit the scene, alot of them look over-bright or the lighting just doesnt match, no matter how much you tweak their settings. They also can get funky with their reflections sometimes, the reflection on a floor might start a few inches from their feet as opposed to right at the feet as they should. And they don't do well for aerials, once you get above a certain angle they look odd.
I'm not a huge fan of them, but maxer is right..... they work well, but don't go in to your purchase thinking they're perfect. So it's a trade off. RPC's are more realistic, but sometimes they kill the realism of the scene buy not matching the lighting and the stick out like sore thumbs. Some of the other libraries you mentioned of modeled low-polygon people will fit with the lighting but don't look as realistic from a close view. So it basically depends on how you plan on using them.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old September 21st, 2006   #7 (permalink)
Singapore
That's very weird artifact that you showed me from archvision 3D people. I have made a decision and will purchase some from www.proviz3d.com and www.axyz-design.com
Thanks for all your help
rgds
WT
Old September 21st, 2006   #8 (permalink)
Singapore
Just wondering, does the rpc people requires rigging like the rest ? or they work with some sort of plugin? they are quire expensive for $75 for each people, I can get 8 people in axyz and 10 in proviz3d.
rgds
WT
Old September 21st, 2006   #9 (permalink)
Maxer's Avatar
No the RPC people are all pre-programmed which makes them much easier to use and much more valuable in an animation situation. That's one thing I don't like about AXYZ people, you either have to animate them your self or use their MOCAP data which I still haven't figured out how to use yet.
“There is no spoon”
Maxer is offline
Old September 21st, 2006   #10 (permalink)
BrianKitts's Avatar
not necessary a rigging..... but you do have to install the (free) max plugin from archvision. Which will allow you to mass populate/edit the rpcs. They also have a plugin that will allow you to drop RPC content directly into photoshop.
Brian Kitts
ANSHEN + ALLEN
textures of sitting people... and a chef... skogskalle General Discussions 6 July 13th, 2006 03:50 AM
Intero Visuals 3D Furniture Collection Vol 1 Jeff Mottle CGA VM Store 1 June 23rd, 2006 09:29 PM
3rd World Memorandum Archmage General Discussions 24 May 18th, 2004 02:27 PM
New Collection from LowPolygon.com 3D model people Richard McCarthy General Discussions 1 September 18th, 2003 07:11 AM
