Old September 21st, 2006   #11 (permalink)
Maxer's Avatar
Default Re: Screen Resolution
Sorry what is PAR?
Manta, it's really a mess, were not actually producing the video that will be done by a marketing company that has yet to be picked by the client. Basically I'm just providing the animations and they are going to assemble it so because we don't know who were working with yet I don't have any idea what there using.
“There is no spoon”
Maxer is offline
Old September 21st, 2006   #12 (permalink)
manta's Avatar
I believe PAR is pixel aspect ratio...
I would suggest doing some experimenting, and make a dvd yourself...use something faster than maxwell for the experiments though...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old September 21st, 2006   #13 (permalink)
Hong Kong
hi,everyone,i'm a interior desin image maker,i use 3d max for interior visualize CG ,
if you want a interior Perspective ,
you shall contact me ,
my MSN: chenzexin007@chen.com
my email:chenzexin007@126.com
chenzexin is offline
Old September 21st, 2006   #14 (permalink)
Maxer's Avatar
Wow chenzexin that really helps out a lot, thanks for taking the time to post.
“There is no spoon”
Maxer is offline
Old September 22nd, 2006   #15 (permalink)
Shetland Islands
I'm a PAL guy, so I hope I'll not mess up the numbers ;-)
For NTSC widescreen the final output will have to be NTSC widescreen MPEG2.
I think the numbers above are right... in which case it's 720x486 with a pixel aspect ratio of 1:1.2
If your render software can't do different pixel aspect ratios, then you can render to 864x486 in square pixels, and the image covers the same size, so you will have no stretching or cropping issues later.
The exact sequence of what you need to convert and when will depend on the way you produce the final edited source for the MPEG encode, and what software you encode with.
Either way there should be no disadvantage with rendering at 864x486, other than the loger render times.
colinsmith is offline
Old September 22nd, 2006   #16 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
EXCEPT
if the encoding software forces a PAR on you. You need to test these things. Make a test frame at 864 x 486 that has a circle in the middle going from top to bottom, and another shape, maybe an oval, that goes from the left edge to the right. Make it a 10 second 'clip' and export it as if it was your final footage. Check the result for cropping and proper proportion. Then you'll know for sure what you're doing.
What's the answer on Maxwell and non-square pixels?
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Image size and resolution blair Photoshop 4 May 24th, 2007 09:06 AM
Material resolution in viewport aflack 3ds Max 8 July 17th, 2006 10:02 AM
Image resolution? antonio_frias 3ds Max 5 February 27th, 2006 10:51 AM
rendering for an outdoor LED SCREEN dnaranjo General Discussions 2 January 11th, 2006 12:36 PM
window opening off screen?? C.Vestal General Discussions 2 July 1st, 2004 04:36 PM
