3ds Max Autodesk 3ds Max
Old September 21st, 2006   #1 (permalink)
Default compatible revit and max?
hey, does anyone model in revit and import into max for better quality renders? ifso which is the best way? i noticed that all walls import as the same layer, so i makes it hard to apply different materials
i know this should be in revit forum, but it seems a bit quiet there
thanks
dave
foorked1 is offline
Old September 21st, 2006   #2 (permalink)
VelvetElvis's Avatar
Name: Scott Schroeder
Default Re: compatible revit and max?
Way back in the day I used to bring objects out of revit into max. Then I saw the light and just modeled in Max. However, it seems that there should be a better max exporting tool available since Autodesk has Revit now.
Also, you can always just detach objects once inside max and apply different materials there. You dont need to stick to the layers that Revit gives you or set up your layers in Revit so that differnt types of walls import into different layers in Max.
Take a look at your Max import settings as well, and make sure things are importing by layer and that may help as well.
Scott S.
VelvetElvis is offline
Old March 12th, 2008   #3 (permalink)
Smile Re: compatible revit and max?
hello,
you should take a look at our Revit to Max product. It provides the higherst quality render mesh on the market.
http://npowersoftware.com/translator...x_Overview.htm
Npower is offline
Revit Max, and Autodesk Jefferson Grigsby General Discussions 3 March 13th, 2008 09:15 AM
Revit model in max??? akzit 3ds Max 4 March 13th, 2008 03:51 AM
Revit To Max, Why Such A Nightmare?? Jefferson Grigsby AutoCAD/AutoCAD Architecture 2 August 5th, 2006 12:28 PM
Revit to Max 6 CT 3ds Max 0 January 14th, 2004 12:44 PM
