Wow. All these are great explanations from different areas. I like it. Thank you, guys.
Originally Posted by MasterZap
I generally recommend to turn on translucency for glass, set the weight to about 0.1 and the translucency color to white (wince this is filtered "through" any "refraction color" you put in).
/Z
MasterZap: In Falloff map, the black color will allow the light pass through it. The white color won't. But you put white in translucency. Are you sure? I will do a small test later.
