Old May 4th, 2003   #1 (permalink)
I need to show these renderings to a client and I just can't figure out why they are so uninteresting.
Any comments welcomed.
South View
North View
(Autocad to Max to Lightscape & back to Max)
thanks
Joseph Petrino is offline
Old May 4th, 2003   #2 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
I agree about the 'un-interesting' and I am having a hard time answering 'why'. Are the colors accurate? That orange is a bit unfortunate.
OK--try this--make the floor more red, make the upper walls/ceiling more white. That will give the space a bit more life, and make it more unified as a colorful lobby. Alternatively, knock back the color on the orange.
The first view has the problem of what you see outside being far more interesting than what's inside. Try to bring down the contrast and saturation of the bitmap for outside.
I did a few quick bits with curves, dividing the image into ceiling, orange and floors. Judge for yourself it is going in a 'better' direction:
Can you take some licence and add a subtle color fade (dark cools towards lighter warms) in Photoshop?
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old May 4th, 2003   #3 (permalink)
kid
kid's Avatar
the blurring of the street beyond, in the first image makes it feel like I'm looking into a little doll house with my eye hard up to it.
The second image, those doors look like empty bookcases, and I get the feeling of emtiness and desolation because I keep thinking, "when are they moving in, and fill those empty bookcases".
I took the liberty to butcher your image in photoshop, I think Ernest had more success.
cabbages
kid is offline
Old May 4th, 2003   #4 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Hi Joseph,
Why not add a subtle blurred reflection to the floor (only on the tiles, not on the gaps).
Do chamfer the edge of the desk at the right because in real life there are no hard edges.
rgds
nisus
nisus is offline
Old May 4th, 2003   #5 (permalink)
Thanks for the comments.
The colors are all correct as is and the floor is really that dull finish.
I'm thinking the design is uninteresting.
How could I fix the view outside?
thanks
Old May 5th, 2003   #6 (permalink)
bigcahunak's Avatar
I think that Josephs original colors are better...
but why is it so empty there. Fill the counter with some objects on it, some planters on the floor...
Architecturally, there is nothing tying the upper white walls with orange color under it. Either repeat some white on the bottom, or some brown/orange on the upper part. You can also use vertical objects to tie them (like a long and narrow vertical flag...)
but first, fill the place up.
good luck.
bigcahunak is offline
Old May 5th, 2003   #7 (permalink)
yeps, i agree with big , overblown lights are cool but donīt show the space as well. your image isnīt balanced because your right side is to strong, so if you choose to use people in there you should place some more to balance the render (maybe a centered one). Iīll try something quick in photoshop to show you.
sergio rocha is offline
Old May 5th, 2003   #8 (permalink)
http://www.cgarchitect.com/forum/fil...file=North.jpg
Old May 5th, 2003   #9 (permalink)
bigcahunak's Avatar
Yup, Sergio made it much better already. Infact, that girl alone is...
Old May 7th, 2003   #10 (permalink)
Yes, that does look a lot better.
Đ Copyright 2001 – 2008 CGarchitect Digital Media Corp. All Rights Reserved.
