Old February 20th, 2008   #7 (permalink)
Justin Hunt
Justin Hunt's Avatar
Default Re: Distributed rendering issue, Max 2008
check the firewalls on all machines, you may need to add the .exe files in the mentalray saterlite folder to the exception lists.
I too had many problems setting up DBR. I set up everything according to the help files with no luck. It wasnt until I tried the firewall that it decided to work.
JHV
