Re: Hakuei residence
Hi Kittu,
Nice lighting!
Its a good start but this isn't your final image right?
If it is;
- you need higher irradiance map settings and AA settings,
- You can see the vertical glass lines but not the horizontal? maybe add some detail here.
- I think you can improve the bump off the wood which looks like it is not every where.
- If i look at the photo it looks like the bottom off the window must lower then the floor.
Other then that, there is some post work to do (levels, contrast).
Good luck hope it helps a bit!
