Old September 1st, 2002   #9 (permalink)
penguin71
Guest
Posts: n/a
Name:
THank you abicalho for the reply
Now I can be sure that I must add light with only specular on to solve the problem.
Thank you very much
I appreciate
Can I ask you why in some cases the light come in to the room inside the corners? (the room s modeled with box primitive and inverse normal)If I put the meshing 0.20 (unit in meters)it gives the same problem .Must I reduce the meshing parameters to 0.05?
Excuse me for the second question.
But you are of the DISCREET GRoUP, who better than you can give me some suggests?
THANK YOU
