3ds Max Autodesk 3ds Max
Old October 3rd, 2006   #1 (permalink)
Netherlands
Default Modelling walls and Material Problem
Hi all
I'm having problems assigning material to the house presented in the attached file. As you can see, I used a combination of boxes to build the house and when I assign the material it is visible the existence of different boxes... I could create a surface and use the "quick slice" tool to make the right cuts and use only one shape to model the wall...If so, I get a modelled surface viewing from outside, but If I look behind the wall (interior house viewing) I won't be able to see the cuts I made in the surface
Any help??
Thanks a lot!!
drvox is offline
Old October 3rd, 2006   #2 (permalink)
nazcaLine's Avatar
Peru
Default Re: Modelling walls and Material Problem
what i see is just a mapping problem. Use the same uvwmap for all the elements. Even more, select all thegeometry with these material and apply a uvw modifier (this would be an instanced modifier).
"I have nothing to do with the real world anymore. Please don't insist."
Eduardo Romero
nazcaLine is offline
Old October 3rd, 2006   #3 (permalink)
HomeBrewTJ's Avatar
The mapscaler modifier is always useful, too.
HomeBrewTJ is offline
Old October 4th, 2006   #4 (permalink)
Netherlands
Thanks a lot..Got the problem solved...
Anyway I think it would be much easier to model the house using splines, quick slice tool and extrude... but when I make some cuts, they are only visible from one side of the surface....
Does anybody know why does that happens?
I Have those walls made with boxes and wanted to create holes to put windows and doors...
Thanks,
Regards
drvox is offline
Texture/ Material Problem architect-sma Autodesk VIZ 4 December 15th, 2005 05:33 PM
Render Elements by Material? G-Buffer? MegaPixel 3ds Max 19 September 1st, 2005 10:39 PM
ADT Door material m_cubed Autodesk VIZ 2 August 9th, 2004 04:20 PM
vray material refelcting too much of the background hat-rack General Discussions 3 July 5th, 2004 06:04 AM
Assigning Material in VIZ5 Wampa Autodesk VIZ 4 May 24th, 2004 01:02 AM
