Originally Posted by Mazinger
So on XP 32bit, in a certain way 4GB can be used? You mean that, in a way of speaking, one application can use 2G, and another the other 2G?
What's that 3gb switch?
From the Microsoft support site,
"Operating systems based on Microsoft Windows NT technologies have always provided applications with a flat 32-bit virtual address space that describes 4 gigabytes (GB) of virtual memory. The address space is usually split so that 2 GB of address space is directly accessible to the application and the other 2 GB is only accessible to the Windows executive software.The 32-bit versions of the Windows 2000 Advanced Server and Windows NT Server 4.0, Enterprise Edition, operating systems were the first versions of Windows to provide applications with a 3-GB flat virtual address space, with the kernel and executive components using only 1 GB. In response to customer requests, Microsoft has expanded the availability of this support to the 32-bit version of Windows XP Professional and all 32-bit versions of Windows Server 2003.
Windows 2000 Memory Support. With Windows 2000 Professional and Server, the maximum amount of memory that can be supported is 4 GB (identical to Windows NT 4.0, as described later in this section). However, Windows 2000 Advanced Server supports 8 GB of physical RAM and Windows 2000 Datacenter Server supports 32 GB of physical RAM using the PAE feature of the IA-32 processor family, beginning with Intel Pentium Pro and later.
Windows XP Professional and Windows Server 2003 Memory Support. The maximum amount of memory that can be supported on Windows XP Professional and Windows Server 2003 is also 4 GB. However, Windows Server 2003, Enterprise Edition supports 32 GB of physical RAM and Windows Server 2003, Datacenter Edition supports 64 GB of physical RAM
using the PAE feature.
The virtual address space of processes and applications is still limited to 2 GB unless the
/3GB switch is used in the Boot.ini file. When the physical RAM in the system exceeds 16 GB and the /3GB switch is used, the operating system will ignore the additional RAM until the /3GB switch is removed. This is because of the increased size of the kernel required to support more Page Table Entries. The assumption is made that the administrator would rather not lose the /3GB functionality silently and automatically; therefore, this requires the administrator to explicitly change this setting.
The
/3GB switch allocates 3 GB of virtual address space to an application that uses IMAGE_FILE_LARGE_ADDRESS_AWARE in the process header. This switch allows applications to address 1 GB of additional virtual address space above 2 GB.
The virtual address space of processes and applications is still limited to 2 GB, unless the
/3GB switch is used in the Boot.ini file. The following example shows how to add the
/3GB parameter in the Boot.ini file to enable application memory tuning:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINNT="????" /3GB
Note: "????" in the previous example can be the programmatic name of any of the following operating system versions:
Windows XP Professional...:
