Old February 26th, 2008   #1 (permalink)
JamesTaylor
Default Accuracy of Viz / Max Sun System
A collegue of mine has been asked to use Viz in order to compile some Sun analysis renders from which the design / position of Brise Soleil can be obtained.
I'm sure i've read somewhere that the max / viz sun system isn't that accurate?? I've had a quick search here but not turned anything up, can anyone confirm the accuracy of the the max / viz sun system, are we talking 80% / 90% / 95% accuracy??
has anyone else produced sun analysis with the sun system to deign brise soleil? were the results good enough?
JamesTaylor is offline   Reply With Quote
